Sharing VRS signal
Posted: Thu Jun 08, 2006 2:59 pm
Suppose you have an ECU that uses VRS and 36-1 tooth gear, and you want to install EDIS + Megajolt and still use that same VRS sensor. How would one go about this? Is there a circuit that could be made to share this single VRS. I know that connecting VRS to ECM and EDIS in parallel won't work, since both ECM and EDIS send a refernece voltage to VRS.
I'm thinking of a circuit that would read VRS and have inputs for ECU and EDIS and madulate those inputs accordingly. Electronics is not my thing though, please somebody think of a simple solution. Just image you want to run two EDIS modules off a single VRS sensor.
AL
AL
