Hi there,
I need to get a USB > Serial cable - and looking on eBay most of them are USB > female serial.
Will this plug directly in to the MJLJ?
James
Serial cable question
Triumph Spitfire Mk3 1969
Triumph 2000 Mk1 1969
All the ones I see are USB >
All the ones I see are USB > male serial eg
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0000679563
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 9741859776
etc
So I'm a bit confused
They are like this so that they give you the same RS232 connector that you would have on a PC if you were to have a real RS232 serial port on the PC ie male pins sticking out.
If you get one like the first URL above, then it will plug straight into the MJLJ - you need to make sure it's long enough if you have the MJLJ mounted in the car however.
Or you can plug a normal "straight-thru" serial extension cable into the adapter with 9-pin female at one end (for the end of the adapter) and 9 pin male at the other end (for the MJLJ). Like this one..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 9745037004
etc
There're loads of options
You can use the USB>Serial bridge with a short straight through serial lead, or use a USB extension like this -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 9742698695
You'll just need to unscrew the retaining nuts from the DB9 MJLJ connector.
Gilesy998
1980 Leyland Mini 1000. Stage one tuned.
10" wheels. 4-pot brakes. MJLJ V3 ignition controller.
Yes I am ;-)
Yes I am
I meant male...
Ordered one that should plug straight in to the MJLJ then- nice and easy.
I meant male...
Get these
You will need
1 <a target="_blank" href="http://cgi.ebay.com/New-USB-to-RS-232-S ... -Serial</a>
1 <a target="_blank" href="http://cgi.ebay.com/Serial-Extension-Ca ... Item">DB9F DB9M serial cable, 25 feet</a>
Should be $10 and $15 from eBay
Once you get USB-to-Serial, first thing you should do is pop the CD in and install drivers, Before you insert the adapter into the USB.
