turbo VW bug options
Posted: Mon Jul 31, 2006 4:59 pm
I've got a turbo 2 liter in a VW Karmann Ghia with a weber side draft. I was running dual spark plugs using an old airplane dual distributor. It ran fine for years then the distributor bit the dust. I searched this site & it looks very promising. Here are my questions I could not find answers to on the site.
Can the MAP sensor handle boost? I'm looking at 10 psi max. If not, what MAP sensor would I need & how extensive would the modifications be to using it.
Since I am running dual spark plugs, I assume I would use the program for 4 cylinders, but run 4 dual coils, for a total of 8 plugs. 1 dual coil then feeds 2 plugs on the same cylinder.
