Which MC68HC908XK8 (Now PC Errors)
Both chips are the same, but
Both chips are the same, but if you have a V2.X board and a V3.x board, the MJLJ firmware is different.
If you didn't keep track of which processor came with which board, the safest thing is to re-program the 2.x firmware onto the 2.x board, and re-program the 3.x firmware onto the 3.x board.
MJLJ project & site admin
MartinM
No difference -
Post by MartinM »
---content deleted---
I posted, I got in the car, I drove home, I thought about what I posted, I realised it was completely misleading, I got home, I deleted it!
tedzbug
trying new firmware
Post by tedzbug »
Ok....Now i get an error:
C:\MJ>hc08sprg COM1 mjlJunior_3.0.0.s19
Waiting for HC08 reset ACK...received 0xfc (good).
Can't read MCU info (forgot to set single wire mode?)
tedzbug
Post by tedzbug »
I have both chips because i originally bought the earlier board, then bought the late board and processor........ Now i am assembling and dont know how to tell them apart. One has an obvious
motorola logo on it.
the numbers on both chips are:
Motorola chip
MC68HC908
KX8CP 2L09H
CPAH0403
Other chip
MC68HC908
KX8CP 2L09H
CPAA0552
Troubleshooting the
Troubleshooting the above:
Are you interrupting power after it sees the chip?
Have you tried a different serial cable?
Does it happen with the 2.x board and 3.x board?
tedzbug
the power was cut possibly
Post by tedzbug »
the power was cut possibly while programming....... it sat forever (counting up) after it seemed to work uploading firmware. so i unplugged it :(
did i mess up the chip? do i need a new one? it worked before that.
Cutting the power during
Cutting the power during programming does not matter- the bootloader code is not touched during this process. I would just try again. If you still have problems, try the other suggestions-
tedzbug
finally...... I plugged
Post by tedzbug »
finally...... I plugged into my old laptop (the one i will program in-car with) and it had no problems with communication.
Flashed my chip. Ready to install in the car now.
Thanks for the help
