Ordering Megajolt...
Hi Nick, I've noticed that
Hi Nick,
I've noticed that the DigiKey order form needs to be updated, as some of the parts numbers appear to be deprecated. I'll look for suitable replacements and update the form soon.
What would be the interest of a full parts kit to make things more convenient?
nickkeyser
Post by nickkeyser »
I am looking to install MegaJolt onto a Fiat FIRE 1240 16v engine from a punto sporting, this engine used to run efi but to get it going in my reliant kitten racer i will be running it on carbs (for now...), probably somthing like weber DCNFs (im tight for room and down draught seems the obvious option) and this system seems perfect for getting around my ignition problems (such as not having anything at all on the end of my plug leads!)
my questions are:
- i am un decided as to run a TPS or MAP sensor, the manifold will be a fabricated steel affair so adding a 'log' type ballance tube (bit of pipe with 4 little pipes welded strait on the side) would be easy, although not to well flowing - does this matter? what sort of size plenham should i stick in the middle of it all?
Alternativly, has anyone fitted a TPS to a weber weber DCNF?
- my second question is: is their a list of componants with RS or Maplin part numbers, as i live in the uk and there are some difficulties ordering the bits from the states (Half of them are not available)
Many thanks
Nick
nickkeyser
Brent with regards to a kit,
with regards to a kit, i personally think it would be realy useful, or atleast a list of the seperate components and values, maybe with part numbers for a few suppiers - im sure we could compile it on here with relative ease if it doesnt already exist.
Cheers
Nick
bhwm
Parts List
Post by bhwm »
Search the forum for <b><I>uk parts</b></I> - the first couple of results include some lists for Farnell. The stock numbers may be out of date now though, due to the change to RoHS compliant (lead free) parts.
You should be able to get most of the parts, or similar alternatives, from Rapid, Farnell or RS. I agree it would be useful to have an up to date list for some UK suppliers.
Pmoffatt
Parts kit...
Post by Pmoffatt »
A full parts kit from a UK distributor would be nice. :D
