Thankfully i went with your diagramme.brentp wrote:In a way, they are both correct. Whatever scheme you use it's important you match the HV plug wires to the correct pistons so the plugs fire correctly. It will be extremely obvious if you have the plug sequence incorrect.
We have documented the 2nd approach, with pin 10 going to pin closest to the coil pack notch.
http://www.autosportlabs.net/MJLJ_V4_ve ... stallation
