Relay wiring?
coozer
Relay wiring?
Post by coozer »
Searched the forums and can't find my question.
Using one of the programmable outputs to switch a relay to activate VVT at 4000rpm....
Is it safe the wire the output to pin 86 with a +12v on 85? Will this switch the relay OK? Does it matter what type of relay? (rating)
Steve
Gilesy998
Post by Gilesy998 »
That should be fine, and any automotive relay is suitable - at least you're not trying to run your fan direct off the output :lol:
