Holden (GMH) module and sensors
Brockster
Post by Brockster »
Hi from Aus
I am going to put an ecotech V6 holden motor in my Ford courier ute. I hate petrol and run LP gas only so the engine is stripped of it's wiring and I will be starting from scratch. The fuel side is no problem, GasResearch is the only way to go but I need a strong spark to run the high compression gas loves which brings me to this system which looks the way to go. I was wonering if anyone has used this system on one of these engines? Can you use the GM module and sensors? I have included a link which gives some info on the system. As you can see it is a wasted spark system but it has two sensors triggering it. Any help would be great.
http://www.megamanual.com/ms2/GM_DIS.htm
The only LPgas sytem to run and they can even put them on diesels. Yuck
http://www.gasresearch.com.au/
Brock,
The Megajolt Lite Jr is designed to only work with the Ford EDIS module. In your case, you would need an EDIS-6 unit and mount the necessary trigger wheel. Upcoming Megajolt 2 variants will not depend on the EDIS module and ultimately support a variety of trigger wheel patterns. Keep an eye on our news and announcements section for an update!
Brockster
Post by Brockster »
Sounds good. Any release date yet for megajolt 2. It is a bit harder to get the Ford parts readily in OZ.
Spockie-Tech
Post by Spockie-Tech »
Just type EDIS into ebay, and they are delivered to your door.. cant get easier than that.. I have bought about 6 sets so far :)
