Ok gang,
as I've had progress one step at a time,gaining spark was my last achievement on my 1,8 pinto'd Sierra. And now,downloading the correct firmware was another hurdle (as picture below),but now sorted.
So,got the laptop out and having downloaded the 2nd and 3rd maps from >here<. I've only opened the 2D map and the reading on the ignition advance was 12,and the revs weren't settled,going from 600 to 1000. I don't have an air filter on the DGAV carb,so that might have an influence on unsteady idle rpm.
Can the timing be adjusted via laptop-->MJLJ?
Do I need to download the maps to MJLJ,if so,what do I click on?
thanks
Paul
first contact with laptop
- firmware.JPG (28.71 KiB) Viewed 8979 times
Hi Paul,
I take it you downloaded the 3.2.1 configuration software which got you past the error message?
Before you proceed further, have a look at our software operation guide, starting here with the quick reference, then proceed into how to upload maps, edit ignition on the fly, etc.
http://www.autosportlabs.net/MJLJ_V3_Op ... ain_Screen
I did a search which led me to this topic http://www.autosportlabs.org/viewtopic. ... da51c722a7brentp wrote:Hi Paul,
And that put me right
Brilliant! Thanks Brentbrentp wrote:Before you proceed further, have a look at our software operation guide, starting here with the quick reference, then proceed into how to upload maps, edit ignition on the fly, etc.
I am up to map version 15, I keep making little tweaks to it, driving, testing, etc. No dyno for me yet, I just copied the centrifugal distributor map and went from there. My full load curve mirrors the 009 dizzy, except at high rpm I have added some retard. All the load(TPS) curves I guessed at and am very happy with it now. I just have to finish up my aux input and warmup compensation.
How did you do that? I should have done that first.DannyP wrote:I just copied the centrifugal distributor map and went from there.
lovely,sounds like progressDannyP wrote:My full load curve mirrors the 009 dizzy, except at high rpm I have added some retard. All the load(TPS) curves I guessed at and am very happy with it now. I just have to finish up my aux input and warmup compensation.
More advance, only when cold, only at TPS low or throttle closed. It only takes 3-5 minutes before the head temps come up, but the idle is too low until warmed. Chokes on dual Webers don't work very well, you end up intaking a lot of dirt.
Sierra, I wrote down readings at various rpms with a timing light before I pulled the distributor.
