Need a little help
didly
Need a little help
Post by didly »
Hello, just looking for some advise concerning the upgrade of my Megajolt. I purchased the unit in 07 to transplant a zetec into a GRP 4 mk1 escort. All worked ok and had engine running on MJ with no hassles. Since then the whole setup has sat in the couboard until a couple of weeks ago while completing bodywork. Reinstalled all the ignition components and noticed that i didnt have the corresponding configuration program for my MJ. The unit is a V3.2.1 version. Can i run a later version of the configuration program or do i need to upgrade to the later firmware as well, if so is this all i need to upgrade or is there other components to install as well
Thanks Mik
Gilesy998
Post by Gilesy998 »
The Firmware and Configurator must correspond, there are updates in the config that older firmwares will not support. If you need to update the firmware, it's a reasonably simple process requiring a bit of DOS use, detailed in the Wiki guides.
Hi Mik,
You can download the 3.2.1 configuration software here: http://www.autosportlabs.net/asl_dist/m ... v3.2.1.exe
didly
Post by didly »
Mik
