hi i have got a megajolt version 4 set up on a mini and i am trying to get it working on vista 32bit with a maplin serial to usb i have tryed it on my mates xp netbook and it works fine
but after i configure the com port to which ever one i am using i still get the same message "cylinder count timeout" is there anything else i should do on vista to get it working
another vista problem
Benno,
Your problem is most likely the software for the USB to serial adaptor. These are almost notorious for this type of trouble. Search the archive of this forum to find the results of others battle with this issue. I dodged this trouble because my laptop has a serial port. I hope someone else can chime in with more help for you.
Good luck,
Good luck,
Paul
Spitfire driver since 1985
