I'm installing MJ in dodge neon, it is a 2.0L 4 cylinder engine. It uses GM HEI ignition, and has the following trigger wheel setup:
<a href="http://www.autozone.com/servlet/UiBroke ... jsp">Click here for Neon's crank sensor information page</a>
Can I hook up EDIS-4 right up to that VRS and expect it to work right out of the box?
...and if not, what do I do? I want MJ in that thing bad!!!
AL
Installing in Dodge Neon using a stock crank wheel?
No, sorry, you will need to
No, sorry, you will need to mount an EDIS wheel to your crank. Your best bet is usually mounting to the front pulley. I think 3 different sizes are available stock. The 4cyl 1.9L is about 5 1/4" diameter. You will need to research the other two. The second rout would be to have a cusom unit built or have it machined directly into your front pully or dampner.
Todd
Todd
Yep, the ford edis module
Yep, the ford edis module needs the 36-1 wheel, unfortunately.
here are some pictures of how I did it on my toyota 4AG motor:
http://picasso.org/misc/mr2/engine/
http://picasso.org/misc/mr2/engine/timi ... l_face.jpg
