I can't get this thing to communicate with my laptop.
Here is the info:
1) Megajolt Lite Jr. V3.0 bought and assembled + tested and configured with MAP sensor.
2) Installed into the car without bench testing it first.
3) Car is presently running on the basic map that came with the unit.
4) Unit works (tested with the timing light) and the timing advances accordingly with the rpm speed.
5) Tried 2 different serial cables but still no joy.
6) I am getting "unsupported controller version" error.
7) I am using a MJLJ Configurator V3.2.0
What is my next step?
Any ideas how to get this thing to (work) communicate?
Thanks in advance.
Phil
Communications problem with V-3.0
Hi Phil,
it seems the software can talk to the unit, but does not like the version of the firmware in your unit.
Try using an older version of the configuration software to see if you can establish communications:
http://www.autosportlabs.net/asl_dist/m ... v3.0.0.exe
Brent,
Having problems downloading this, I keep getting errors.
Can you please verify if this link is still ok?
Thx.
Phil
Thx.
Phil
Hi Phil,
Good you were able to install it. The V4 controller has a special serial cable, just order it with the cable and it will plug in the same way. Also, the V4 controller has it's own version of the software.
Regarding your account- I think you were registered under the old system, and when we migrated over to this forum software the account I created for myself was newer than my orignal account on the old system.
