I'm almost there with the TVR V8 megajolt install, so far I've had to machine a chunk off the crank pulley, modify the tacho and mess around with the injection loom considerably but I'm nearly there...
The next question involves spark plugs, TVR recommend NGK B7ECS plugs, Am I correct in thinking that these need to be replaced with BCPR7ES type ?
If at first you don't succeed use a bigger hammer
'89 TVR 400SE V8 "Wedge", now Jolted see Powered By !
