"massive" wheel? the xflow one is about as small as you'll find in an automotive application.
OK, "massive" is the wrong expression. I rather meant "plane"
A welded ring gear style wheel is an alternative but it's more work. If your pulley is like the ones we stock then they are hard-anodised so you'll need to strip that off before you can weld, you'll also have to take care to get it all lined up correctly.
That wouldn't bother me. And I still want to tinker a bit and not only take it out of the box
Unfortunately the answer is neither is the right coilpack to suit your current leads.
Damn!
That is why we supply a new set of 8mm silicone leads with our comprehensive "Complete Megajolt package for Ford xflow engines".
This kit looks pretty interesting. But there are two parts in it, I really don't need (marked red). Would it be possible to send me a quotation for a "slimmed down" package, which includes the following parts:
* Megajolt V4 ECU
* New coil pack and connector
* New crank sensor and connector
* Refurbished EDIS Ignition module
* Universal crank sensor bracket
* Coil pack bracket
* Loom kit
* Univeral 36-1 trigger wheel
* Set of 8mm silicone spark plug leads
* Complete with software and mapping cable to allow you to tune the system and maps for a wide range of engines
* Hard rev limiter
Thanks in advance!
