Hi guys, is it ok to use a 2nd Gen Ford coil pack - Motorcraft part no. 988f 12029 ac (like this - http://langemachinery.en.alibaba.com/pr ... 9_AD_.html ) ?
Mine is currently working on a 1st Gen at the moment, with the strange ends on the plug leads - so I'm using an old set of Fiesta leads from the scrappies.
I already have a set of Magnecore leads that I had on the Dizzy setup on my Mini, which are a perfect length to go to the coilpack, but won't fit a 1st Gen coilpack. I think the 2nd Gen use standard connectors on the leads though, so I could use them.... and it's cheaper to buy a 2nd Gen coilpack than to buy a set of Fiesta Magnecore leads for the 1st Gen coilpack!!
Coilpack - Gen 2 ok?
Why buy magnecor leads. We've got 8mm silicone leads to fit 1st gen coils for under 25 pounds per set! See our website www.trigger-wheels.com for more details.
It's a toss up between bodging a set of standard magnecors into a 2nd gen coilpack (they'll fit after a fashion but not what you'd call well and probably not without some modification) which would necessitate buying a coilpack or using the coilpack he has and buying some similar quality leads for a fraction of the price of the magnecors. I know which I would go for but it's a free world and we keep both leads and coil packs in stock in case they're needed.
For future reference we can mix and match lead lengths so if you need short ones or long ones we can generally put together something to suit.
