Tachometer Adapter board
Here's something that neatly solves a nagging problem for nearly all Megajolt installations: interfacing existing Tachometers to multiple coil packs.
http://www.autosportlabs.org/blog/?p=1618
Available now in our online store: http://www.autosportlabs.com/tach-adapter-p-65.html
bossie
Post by bossie »
Looks good :)
(now it's time for some cheaper shipment options ;))
Set up a group buy! :)
Broke4speed
Post by Broke4speed »
Just in time for my new project!
Thanks Brent! :D
molecular bob
Post by molecular bob »
just got mine and it looks good, i really underestimated just how small it would be.
2 questions:
1. Will the solder used for the components melt at the temperatures used to shrink heat-shrink tube?
2. What gauge of wire would be suitable for hook-up?
cheers
Ian B.
In the lab or in the car
dr.occa
Post by dr.occa »
Brent, will this resolve the 4AGE tach signal problem?
Ian,
The solder won't melt at the temperatures used to shrink heat shrink tubing.
Not a lot of current flows through here - small gauge wire is fine and makes it more convenient.
A similar circuit works for my AW11 tach, so it should work for the AE86 tach as well.
Note, this board is not a cure-all for *all* tachometers out there. it has the addition of 100K resistors across each diode which helps make certain tachometers compatible - such as the 914 tach we're using in our race car: that tachometer wouldn't work with just diodes.
toenee
Post by toenee »
If your tacho works, but has a hissy fit bouncing around at higher rpms.
Would this adapter help ?
Toenee,
Can't say for sure. How is it wired now? More info would be helpful.
toenee
Post by toenee »
Sorry yes more info needed, it's wired to the megajolt as per the diagram
toenee, it would probably work- especially if the tach was connected to the (-) of the original single coil.
Ian,
Did you get the adapter board installed? How is it working?
toenee
Post by toenee »
brentp wrote:toenee, it would probably work- especially if the tach was connected to the (-) of the original single coil.
Yep it's a RVC tacho from a MGB, just put my order in cheers.
molecular bob
Hi Brent
Feel a bit guilty 'cos it's not fitted to my megajolt. I am about 2 weeks away from start up on my Zetec Caterham 7 conversion and have fitted a DTA ecu as i want to go injection in the near future. The DTA has simillar issues driving Tacho's so i will let you know how i get on. I used raychem solder splices to join the wires near the ecu by baring a short section of the driver wire and then bonding a 18awg wire from here to the board. It's then all heat-shrinked into the loom.
Tach adapters back in stock!
The first batch flew out the door- we now have plenty of the tach adapters in stock: http://www.autosportlabs.com/tach-adapter-p-65.html
Thank to those who've been patiently waiting!
73tii
incorrect tach reading
Post by 73tii »
My tach is not giving the correct readings at times. It's reading too low. Is this supposed to be a better option and replace the home made "diode circuit"?
Car is a BMW 2002 4cylinder M10 engine. Thank you
