Porsche 550 Spyder Replica
DannyP
Post by DannyP »
VW type 1 aircooled flat4
2165cc, 78mm stroke, 94mm bore, built by Jake Raby of Aircooled Technology
Webcam 86B, Headflow Masters 040, 44 X 37 mm valves
Pauter 1.5:1 roller rockers, Weber 44 IDF X 2
4-2-1 exhaust w/dual Magnaflow mufflers, 3" exit
On firewall behind passenger seat
Ready to put back in
DannyP
Post by DannyP »
More pics:
After I install the rear clip and wash it up, I'll take one of the completed car outside.
It has 10,000 miles on it on a dizzy, now the Megajolt is installed and working!
I am very pleased, thanks a bunch Brent!!
Time for mapping and testing the limiter.
Hi Danny,
Great looking project looks great- would love to see more pictures of your completed Porsche on the road!
paulc
Post by paulc »
yes - thanks for posting the map. I'm about 2 months behind you on a similar project (T4 2L)
Good work. Just out of curiosity - why did you choose the TSP over MAP?
DannyP
Post by DannyP »
Thanks Brent. Will post more soon. Having too much fun driving it now that spring is here :o
Paul, I chose TPS because I didn't want to drill and tap the manifolds. I also didn't want extra hoses and a vac reservoir in the engine compartment. It is busy enough already. It was kind of a pain to make the TPS bracket but the TPS came off the donor Ford. Three wires and a bracket for me is easier than a bunch of hoses.
I've pulled back some of the part-throttle advance values, I'll update the map when I am comfortable that it is a good one all around.
teds
Post by teds »
Intersting project, I had the same job with my mini using a 48 IDA. No brackets available for mounting TPS. Took 3 goes to get it right. But happy with the results. Much cleaner install.
Nice Job. :wink:
Teds
DannyP
Post by DannyP »
Finally adding some pics, as requested! Like two years ago...........
New paint was finished in the spring.
Funky Diver
Post by Funky Diver »
That is one swish looking motor you have there mate, top draw schtuff!
DannyP
Post by DannyP »
Thanks! Paint was done in March of this year. Also added a gas heater with defrost vents too.
Motor puts out 180 hp @ 6000 on Megajolt v3. 147 ft. lbs. of torque just above 3000.
Car weighs 1450 lbs. with a half-tank of gas and no driver.
DannyP
Post by DannyP »
Update to the car. Still running perfectly. The ignition is hands down the best mod I ended up doing. Almost 27,000 miles now. It was around 10-12,000 when I installed the ignition. I ended up making a three-light sequential limiter by using three rpm outputs. I used another output to trigger a 12v solenoid that opens up a crankcase evac exhaust venturi above 5000 rpm. Also wired up temperature compensation(a bit more advance at low rpm when cold to increase the idle speed). I have spare new EDIS components in the car, just in case. Dual maps, one for good gas, one for bad.
Kudos to Brent for a VERY flexible, reliable product!
