TPS wiring.. version 3 board..
robbydee
Post by robbydee »
When wiring for the v3 board is this correct?
3 wires from the Weber TPS...
red (5v) goes to vref
black goes to earth
green goes to tps on molex?
thanks..
Long overdue.. here's a link
Long overdue.. here's a link to the updated project information:
<a href="http://picasso.org/mjlj/?q=node/606"/>Vehicle Installation</a>
I borrowed an execellent wiring diagram from Steve Randle.. Will flesh out versions for EDIS-6 and EDIS-8 when I can.
MartinM
A couple of comments if I
Post by MartinM »
A couple of comments if I may....
I find it real confusing having the +12V at the bottom. There's no law against it, but it's usually at the top...
Don't really know what the 25uF capacitor is for...power supply spike suppression? Does it need to be 'near' the MJLJ? etc etc
Not sure what the black +12V is above the red 5V...
I'm happy to have a go at the diagram Brent - just let me know - but I don't want to duplicate effort...
PioneerX
25uF Cap
Post by PioneerX »
The 25uF cap is part of the EDIS setup (The grey block, about the size of a match box) and is there for noise suppresion in the coil lines, it helps to reduce the RF noise that production cars are tested for.
MartinM
I don't have one of
Post by MartinM »
<<The grey block, about the size...>>I don't have one of those...but I also don't have a radio in the rally car, so I'm not that fussed about/have never had a problem with noise suppression!
I *think* I've never seen any grey block in any pictures or words about getting the EDIS components from a car to suit a MJLJ - or am I missing something?
SRandle
Suppresion
Post by SRandle »
The suppressor was fitted for the SVA test on a new build.
In a standard production car this is fitted along side the coil Pack.
PioneerX
25uF Cap
Post by PioneerX »
You can see the Cap on my installation right next to the coil pack. As SRandle said it's part of the orginal loom from the standard production cars.
http://www.locost.pioneerx.co.uk/Nov200 ... GP1227.JPG
