Megajolt Android tuning app
Some good news. Using the MJLJ hardware with the MCU removed I can talk to the Bluetooth module via the serial port on the MJLJ. I get OK when I type AT and have been able to change the baud to 38400 using the AT+BAUD6 command and get the response OK38400. I have then gone back in using PuTTy at 38400 to check comms and AT returns OK so it must all be wired correctly.
I have powered down the module, put the MCU back in the jolt and have paired the phone again, connected the app and no data. Have I missed something?
Col
Col
Here's what I've done so far.
Nice neat connector carrying 5V, Gnd, Tx and Rx all hard wired inside the MjLj:
HC-06 Bluetooth module wired into a small project box:
Fitted up and looking very neat:
Test bench wiring looms (currently using the MjLj hardware to gain access to the BT modules serial port):
Sadly still no comms to the phone app but it looks the part...
Selected and paired to the module. App connects and modules LED stops blinking and stays solid.
Gauges all sat at "0" permanently. If I disconnect the app it says connection lost for about 5 minutes and I usually have to restart the phone to get rid of it, however it will reconnect quite happily but with no comms.
