Megajolt coil
Warning634
Megajolt coil
Post by Warning634 »
Hi everyone
I have a Megajolt system fitted into my mini rally car, it has been running perfectly. I have just completed the fitting of a new engine and now I can't get the engine to run. It starts but does not seem to be able to idle and it does not sound that it is running on all cylinders. The motor was fully running when it was removed from another mini.
I have replaced the spark plugs, checked the tappet gaps and checked that the trigger was at the correct position (9th tooth at tdc) there is a spark to the plugs, but it does seem very very weak and the frequency seems strage.
Here are some videos of the 4 plugs
http://i164.photobucket.com/albums/u40/ ... sunpyv.mp4
http://i164.photobucket.com/albums/u40/ ... xbqzzp.mp4
http://i164.photobucket.com/albums/u40/ ... lgnb8m.mp4
http://i164.photobucket.com/albums/u40/ ... k9yjs8.mp4
Can I have your views as to wether this spark is normal, and how I can sort this out. I need to resolve ASAP as I have an event in 2 weeks. I have ordered a replacement coil as I'm stuck for what it can be.
Many thanks
Kevin
Alex B
Post by Alex B »
How about earthing, has the earth strap between engine and car body been refit again?
Alex
Warning634
Hi
Yes I have refitted the earth strap, fitted to the clutch housing and the engine steady bar against the bulkhead.
Many thanks
Kevin
toenee
Post by toenee »
Have you got resister plugs in ? Can see the BP but can't make out whether there the R after that, also open the plug gaps upto 1mm. I run BPR7ES's in mine with a similar spec engine.
