Hi everyone
I have a Megajolt system fitted into my mini rally car, it has been running perfectly. I have just completed the fitting of a new engine and now I can't get the engine to run. It starts but does not seem to be able to idle and it does not sound that it is running on all cylinders. The motor was fully running when it was removed from another mini.
I have replaced the spark plugs, checked the tappet gaps and checked that the trigger was at the correct position (9th tooth at tdc) there is a spark to the plugs, but it does seem very very weak and the frequency seems strage.
Here are some videos of the 4 plugs
http://i164.photobucket.com/albums/u40/ ... sunpyv.mp4
http://i164.photobucket.com/albums/u40/ ... xbqzzp.mp4
http://i164.photobucket.com/albums/u40/ ... lgnb8m.mp4
http://i164.photobucket.com/albums/u40/ ... k9yjs8.mp4
Can I have your views as to wether this spark is normal, and how I can sort this out. I need to resolve ASAP as I have an event in 2 weeks. I have ordered a replacement coil as I'm stuck for what it can be.
Many thanks
Kevin
Megajolt coil
