Hi all.
I have a megajolt junior lite. I have wired the system up as per the diagrams I have but I cannot get a spark. The next step I'm going to try is swapping the vr polarity. I'm a bit confused as I have a 4 cylinder engine but the coil pack has 4 pin connection and not 3. Is one of these spare?
Running a vauxhall x16xe engine
Coil pack
Don't use any black aftermarket coils, no matter how well they are advertised. They burn out after couple of weeks/month, non-reliable junk.
I was advised to use Red MSD coil PN# 8241 instead.
The aluminum base does not come w/coil. It is a Millers Mule Machine part made specifically for Lotus 910 Engines. http://www.manta.com/c/mmn4g16/millers- ... and-design
- IMG_3824.JPG (188.33 KiB) Viewed 18606 times
