hi all im new to the forum and megajolt but really interested in it, basicly im after a base map or something higher for mw vw golf. engine wise its a 2.0l 16v kr lump with zx9r bike carbs and tps, any help would be muchly appriciated!
cheers Ash
vw 16v kr with carbs map wanted please.
vw golf 2.0 16v zx9r carbs
here are a few maps i run in my vw, these are original base maps that i changed to suit, i have used all 3 but find that no. 2 works the best for my set up. this is with tps.
engine spec..
vw 2.0 16v 9a standard block
vw golf mk2 kr 16v head mild port and polish
276 deg. inlet & exhaust cams
4 branch exhaust manifold with 2.5 inch system
dcoe 40 weber carbs , 36 vent. 145 main. f16 tube, 190 airs, 55f9 idle,45 pump, 4.5 aux. vent.
engine spec..
- golf fix2.mjlj
- this is what i run now.
- (725 Bytes) Downloaded 2345 times
- golf fix1.mjlj
- this was the first attempt
- (725 Bytes) Downloaded 1877 times
- golf fix3.mjlj
- as 2 but with a small change
- (725 Bytes) Downloaded 2053 times
there is no comparison with the original ignition for relibility and performance, and the ability to switch to another map is great, i run normally 95 unleaded but when in germany 100 octane is available from the pump. so a map with more igniton advance, more performance, there is the autobahn after all, it would be a shame not to
file update 2017
- june 2017.mjlj
- this map runs well but lacks advance under 3krpm but fit well with a high comprerssion engine to prevent knock at wot under 3krpm
- (706 Bytes) Downloaded 1269 times
- std. abf 2015.mjlj
- This file is almost a copy of the factory abf map i found and adapted it to fit the megajolt software and runs really well and prevents the revs dropping too low when up-shifting above 4krpm.
- (705 Bytes) Downloaded 1085 times
Thanks VR6, just download and am giving it a try now!cese wrote:hi ,and thanks ,i use you're "golf 3 fix" file in my kr (1.8l) with 82 mm pistons and p"p head with all the dbal info ferrea valve .
it works well but my setting of dcoe etc create a missfire in one cylinder (?..)
