I cant get the configurator to F@#$%kn work please help
cinchdog1
Post by cinchdog1 »
I am rumming Windblows ME, I instaled Java fromm the software page link, then I downloaded the JAVA COMM API and unsipped it. then I copied the COMM.JARR/JAVAX.COMM.PROPERTIES etc to the specified program folders all as instructed on the download page. then I downloaded the 2.0.2. configurator and copied the comm.jarr file to it . as far as i know i did everything correctly, keep in mind however it was all greek to me. in any case everytime i try to start the program i get a window titled
-JAVA VIRTUAL MACHINE LAUNCHER- "fatal exeption occurred. program will exit. I do not have the controller hooked up at this point. I want to use it but thus far i have spent two days pulling my hair out just trying to get the software working--rant rant rant. please help.
Paratime
Decaf?
Post by Paratime »
After installing Java, can you play one of the Java games on that page?
cinchdog1
no, three shots,....and stop shaking
Post by cinchdog1 »
yes, the java does seem to work.
try this: open a command p
try this:
open a command prompt (click start, run, and enter 'cmd'; click OK)
at the command prompt enter:
java -version
What does it report back? Mine says:
c:\>java -version
java version "1.4.2_04"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_04-b05)
Java HotSpot(TM) Client VM (build 1.4.2_04-b05, mixed mode)
Next test:
At the command prompt, change to the directory where you have the MJLJ file installed.
enter at the command prompt:
java -jar mjljTune-2.0.2.jar
any errors show up in the command window?
james st. helens
Have you copied the comm.jar
Post by james st. helens »
Have you copied the comm.jar from the java comm package into the same directory as the MJLJ Configurator.
James.
marty
circuit board
Post by marty »
its possible your circuit board might be missing some of its wiring. my was-when i peeled off the tape holding the chip,2 leads came off,but i found it by comparing to the 2x picture. might help, marty
