sources for 36-1 wheel
BMW320i
Post by BMW320i »
Hi, I got some EDIS 4 parts at the junkyard but I still need the toothed wheel. It's colder than the devil outside and the crank pulley is well-hidden on those FWD cars :) So I'm wondering, is there a secret to removing that part? or can I order one from somewhere and for what price? Thanks
Some junkyards will remove
Some junkyards will remove pulleys from bad engines to stock as individual parts. Ask for a crankshaft pulley from a 97-ish Ford Escort. (if you're in the States...)
The toothed wheel separates with some effort- blow-torch heat might help as well.
capri_turbo
Most front scratters
Post by capri_turbo »
most front scratters don't have the timing wheel on the front pulley, but instead the marks are in the flywheel and the sensor is mounted through the engine block.
If you are lucky, you might stumble across a Sierra 1.8 CVH... this has the timing wheel on the front pulley and it can be prised off with 2 open ended spanners...
failing that, look here: http://www.trigger-wheels.com/
I take it that you are UK based.
BMW320i
thanks for your help
Post by BMW320i »
I'm in the northeast USA (where the record-breaking warm weather has unfortunately subsided). I checked with the parts recycler and they didn't sell crank pulleys so I went and looked at Ford Escorts in the yard again. I found that the crank pulley bolt (19mm) is accessible from the wheel well after removing a plastic cover. So I located a 5-speed Escort, put it in gear, put a monkey wrench in each front wheel, and then I could loosen the bolt and remove the pulley.
piledriver
IIRC they are also available
Post by piledriver »
IIRC they are also available from any Ford dealer for ~$35 US.
4600cc
What are the part numbers
Post by 4600cc »
What are the part numbers for those wheels?
Daryl Smith
Post by Daryl Smith »
The trigger wheel is a bolt on to the damper on some V6 engines. Can't remember if you need a 'torx' or allen key to remove it. Check early/mid 90 Taurus, Aerostar(?), Mustang....
Also, I don't think it's been noted that there is a second VR sensor in the head of the 1.9 L Escorts......
