Is Megajolt compatible with stock EFI systems?
victor rosario
Post by victor rosario »
Is the Megajolt compatible with stock EFI systems? For example Honda, or Toyota 20v black top ECUs wich use distributors.
Victor
The MJLJ was specifically des
The MJLJ was specifically designed to control the ford EDIS crank fired unit, so no- it's not compatible with a distributor ignition.
Brent
87fox351
stuff
Post by 87fox351 »
I think he means will the efi computer still control injection if it sees that ignition that it is supposed to be controlling isn't working?
I was wondering about this myself, though its with the eec-iv control instead of the toyota, both weren't designed for distributorless ignition systems.
Ok- that should be pretty eas
Ok- that should be pretty easy to figure out.
It should work fine. The stock ECU would rely on the distributor and coil for providing it the tach signal. So, you'd have to leave the distributor and stock coil installed, but remove all of the old plug wires and just plug up the HV output of the coil for saftey reasons.
The MJLJ+EDIS would then run completely independent of the stock ECU, getting it's tach signal from the crank sensor.
victor rosario
Thank you for the info.
Victor
car1987
what to do
Post by car1987 »
what about the tack out puts on the Megajolt and EDIS?
i have everything hooked as you said but i was running a MSD with a tack adapter i did not diconnect the msd from the OEM igniter.should i, i know it will not be used but didnt want to disconnect it untill i got the EDIS +megajolt running.when i try to start the car it turns over but no spark
