EDIS with diferent trigger wheel
tonci
Post by tonci »
Do you guys know if EDIS going to work with this type of trigger wheel: http://www.inet.hr/~artst/msavr/remenica1.jpg ...it is 36-1 custom made steel wheel.
Paratime
Got my finger on your trigger....
Post by Paratime »
Hey Tonci,
The picture just may not be clear enough, but I don't see the missing notch. One notch has to be missing for the EDIS module to sync to #1 TDC. As for the style of notch, it will probably work, but they may not be quite large enough for the sensor to get a clear signal. You'll just have to try it.
tonci
Yes you did see it right. The
Post by tonci »
Yes you did see it right. The picture was taken before the one of the tooths was grind off.
tonci
Just to let you know, it does
Post by tonci »
Just to let you know, it does work...
