What does MJLJ do between rpm sites?
KITT
Post by KITT »
What does MJLJ set the advance to be between rpm/MAP sites?
e.g. if you set the rpm sites to be every 500rpm what does it set the advance to be at say 2300rpm? Does it pick the nearest site (in this case 2500rpm) or does is average the difference between the 2000rpm and 2500rpm sites?
Josh_b
it
Post by Josh_b »
would stay at 2000 until the 2500 site was reached, if i understand it correctly
Oliver Sedlacek
It just uses the lower RPM bi
Post by Oliver Sedlacek »
It just uses the lower RPM bin value. Interpolation between sites is one of the requested enhancements
that's correct. Interpolat
that's correct.
Interpolation will be in the firmware next release, plus a few other goodies. :)
Brent
KITT
Keep up the good work!
Post by KITT »
Sounds good Brent! I've just started soldering my MJLJ together and have 5v at all the correct places :o) Will continue tonight.
Just need to find a toothed wheel now.......
