What does MJLJ set the advance to be between rpm/MAP sites?
e.g. if you set the rpm sites to be every 500rpm what does it set the advance to be at say 2300rpm? Does it pick the nearest site (in this case 2500rpm) or does is average the difference between the 2000rpm and 2500rpm sites?
What does MJLJ do between rpm sites?
- Contact:
It just uses the lower RPM bi
It just uses the lower RPM bin value. Interpolation between sites is one of the requested enhancements
Keep up the good work!
Sounds good Brent! I've just started soldering my MJLJ together and have 5v at all the correct places
) Will continue tonight.
Just need to find a toothed wheel now.......
