My Autocross competition vehicle and R&D platform
1985 Toyota MR2
Megasquirt and MJLJ for engine managment
Turbocharged 4AGZE engine
Mitsubishi 14B turbo
Ford Probe Turbo intercooler
+endless more modifications
Turbocharged AW11 MR2
- mr2_hoosier_profile.jpg (91.3 KiB) Viewed 27148 times
- mr2_hoosier_rear.jpg (41.81 KiB) Viewed 27148 times
- 14b_turbo_mainifold_compressor_test_fit_3quarter.jpg (92.45 KiB) Viewed 27149 times
- heat_wrapped_intake_installed.jpg (117.39 KiB) Viewed 27150 times
- 14b_turbine_view_coolant_ine.jpg (116.82 KiB) Viewed 27150 times
- intake_plumbing_initial_design_complete_end_view.jpg (96.92 KiB) Viewed 27150 times
- march05_dyno.jpg (100.44 KiB) Viewed 27152 times
Interfacing megajolt and squirt
Hello Brent
Neat looking MR2. I noticed that you have a megajolt and a megasquirt on this car. I assume that the 'jolt is doing sparks and the 'squirt is doing fuel. How are you driving the 'squirt? I ask as this is the long term plan for my Caterham crossflow, and i had assumed that i would have to loose the jolt to free up the sensors on the crank and tps (though as your car is turbo i guess you are running MAP), and run spark and fuel from the megasquirt.
Thanks in advance
Ian Brock
Thanks in advance
Ian Brock
In the lab or in the car
Hi Ian,
Yep, the MJLJ is providing the tach input to the Megasquirt using the TACH_OUT signal. Works very well.
Here's a picture of the equipment rack showing both units. the reservoir at the end is for an intercooler sprayer, controlled by one of the MJLJ outputs (set by boost level). The MJLJ at the time the picture was taken is my first V2 prototype unit.
- v2_engine_management_rack.jpg (97.13 KiB) Viewed 27103 times
Brent
I am currently running Megajolt 3.0 TPS on my Tiger Supercat 1800 Zetec, optioned with Shift lights. I plan on adding the map switching soon.
I also am planning on changing to Fuel Injection using megasquirt however I can not work out if I can run both in parallel. I see that you are. However is it only possible if using Megajolt using MAP?
Thanks in advanced, great work
Ian
Ian
There are 10 type of people in the world, one that understand binary and ones that do not.
Running 3.0 Megajolt on 1800 Zetec Tiger Supercat
Using TPS to drive both would be possible in theory, it just depends on what you use as a "VREF" signal. Both the Megasquirt and Megajolt use a 5v Vref, so you could use either the VRef from the MJLJ or the VRef from the Megasquirt. Just make sure both units are grounded at the same location.
The TPS 'in' could be driven to both TPS inputs simultaneously.
In my case, I'm running the megasquirt in Speed-Density mode, and the TPS is used strictly for acceleration enrichment (equivalent to the accel pump in a carburetor). So note that I haven't tested this scenario.
