Mini 1275
Mini 1275
Mini, A+ engine, 1275ccm, normally aspirated, 35,7/29mm valves, ported head, Kent MD286 cam, MAP sensor
- MiniSPi2-MD286.mjlj
- (714 Bytes) Downloaded 2429 times
KLAS, I've borrowed this map to have a look at your settings, cheers.
Hoping to get my 1380 running tonight. It's also on a 286cam, 1.5:1 roller rockers, vernier timing gear, but has a higher CR than standard (11:1) and will be running on UBER fuel with loads of additives. Also on 36mm inlets and 30mm exhausts, inhaling through a 45 DCOE and exhaling through a Maniflow phase 2 with large bore system.
I'll let you know how it goes
EDIT: Wowzers, you've got some serious advance on there!
