Mini 1275
KLAS
Mini 1275
Post by KLAS »
Mini, A+ engine, 1275ccm, normally aspirated, 35,7/29mm valves, ported head, Kent MD286 cam, MAP sensor
MiniSPi2-MD286.mjlj
(714 Bytes) Downloaded 2677 times
Phaeton
Post by Phaeton »
Klas,
Tried to download thsis map just to see what it's like, not up & running yet but it fails to load I get the following error.
Failed to load Ignition Configuration
Could not read configuration file: Malformed data on line 0 (MJLJ)
Might be me, but the file might be corrupted.
Alan...
KLAS
Post by KLAS »
thanks, you are right, changed the file
hope this one will work
Phaeton
Post by Phaeton »
Yep, certainly does
OT does the Kent 286 have advantages over the standard MG Metro cam?
Alan...
KLAS
Post by KLAS »
the MD286 cam revs from 2000-7500RPM and has a lumpy idle, i wouldn't use it again as my mini is daily driven. the MG Metro is a great cam, if you have one stick with it, gives good power.
mafhoward
Post by mafhoward »
KLAS, I've borrowed this map to have a look at your settings, cheers. :wink:
Hoping to get my 1380 running tonight. It's also on a 286cam, 1.5:1 roller rockers, vernier timing gear, but has a higher CR than standard (11:1) and will be running on UBER fuel with loads of additives. Also on 36mm inlets and 30mm exhausts, inhaling through a 45 DCOE and exhaling through a Maniflow phase 2 with large bore system.
I'll let you know how it goes :P
EDIT: Wowzers, you've got some serious advance on there! :shock:
KLAS
Post by KLAS »
hope it helps you get it running
mafhoward wrote:EDIT: Wowzers, you've got some serious advance on there! :shock:
yes, but it works, and i'm running 95 octane fuel with about 9.75:1 (i know it should be higher, next head will rise it, and 98 octane will be needed)
but listen for knock :!:
Salamander
Post by Salamander »
i don't speak english, but try to understand me.
i have a A-series, 1380cc, 36mm inlets and 30mm exhausts, Swiftune 5, 11:1CR, 1.75SU, LCB, 1.5:1rockers
what config i used to this engine?, whit TPS.
please upload the config to load in the MJLJ for testing.
thank's
