thx guy's.
Those leakey WBX are actually very nice and strong engines if you sort out the "small" issues regarding leaking.
Crank and case are bulletproof. great for turbo/torque.
I have experimented with turbo on a couple of other WBX engines , in a beetle i had. and the can handle a descent amount of boost.
Now i run 15PSI but had i up in 21PSI . (wastegate issue
The grille is from a Superbeetle decklid... got to have some air to the radiator if front.
I try to use VW parts as long as it is practical.
