Vacuum position
luke6040
Vacuum position
Post by luke6040 »
I have read that the vacuum cant be taken from the base of the carb , as it is on my mini.
Is this true as i have also been told that it can go here :shock:
Thanks.
KLAS
Post by KLAS »
that depends on what kind of carb you have. there are SU carbs with and without suitable vacuum take off
Gilesy998
Post by Gilesy998 »
You're best to take the vac signal from somewhere well beyond the throttle butterfly. As I understand it, the SU's stock vac takeoff is actually partially blocked at part throttle, meaning the signal seen is a lie. Discussed here - http://www.minifinity.com/index.php?nam ... ic&t=73009
I've added more than one takeoff to my inlet manifold tov allow testing of various sources.
luke6040
Post by luke6040 »
is a su hs4 with the vacuum niple actually on the carb
alexander
Post by alexander »
hi. i will make the assumption that you are referring to the vacuum advance takeoff?
if so, then it is usually not suitable. the reason is that most carburettors have a vacuum advance
takeoff that is covered by edge of the throttle plate when your foot is off the accelerator and
sees no vacuum in that position. when opened even slightly, the hole is uncovered and finds
itself on the inside of the throttle plate, and sees full vacuum. so, as the thottle plate closes,
vacuum gets higher and higher, then drops to nil as the plate closes, and that discontinuity is
difficult if not impossible to account for with an ignition map.
i cant say as a fact how many carburettors are configured that way, but i believe it is the norm.
either way, it is not hard to test for: just pull the vac advance hose from the distributor and put
your finger over the end of it at idle. is there any vacuum? if not, then you need to find somewhere
else from which to take vacuum.
fyi, this is done to make it easier to achieve stable idle.
regards
alexander.
KLAS
Post by KLAS »
luke6040 wrote:is a su hs4 with the vacuum niple actually on the carb
there are two versions, one thats not usable, like alexanders says. this is with the nipple a bit closer to the dashpot. and then there is the version with the nipple closer to the flange, this sees "full vacuum" all the time.
the last one was more common with the later Minis over here.
sadly, i have sold every carb i owned so i can not make any pics.
Gilesy998
Post by Gilesy998 »
This, on a HIF44, would be no good -
Likewise, on a HS4 -
luke6040
Post by luke6040 »
this has been buggin me now because i want to fit megajolt onto my road car and dont wanna mess about strippin manifolds off until i finish my new engine.
So would this solve the prob.
http://minispares.com/Product.aspx?pid=34395
New Carb Spacer for HS4 carbs with vacuum take off.
Gilesy998
Post by Gilesy998 »
That's perfect. If you have the stock mainfold spacer, just bin it and fit that one in it's place. The difference in thickness will make no differenrce on a road car. If you've not got the spacer, just stick that one in, but make sure the carb won't foul the bulkhead - my HS4 fouled when fitted to an alloy inlet fannymould, so I dropped the stock spacer.
luke6040
Post by luke6040 »
well i have the stock spacer so i can do a straight swop! Im very happy now lol, iv gotta get it off anyway as its leakin like hell from there anyway!
I think this new spacer is small so should also give me a lil more clearance :lol:
Thanks for help
Luke
KLAS
Post by KLAS »
Gilesy998 wrote:This, on a HIF44, would be no good -
i've been running HIF44 and HS4 successfully. thats why i said to check the carb first. there are 2 versions
