1380 mini maps?
mr_bridger
1380 mini maps?
Post by mr_bridger »
Anyone got a map for a 1380 NA mini? need a staring block to work from, so any 1275+ ebgine map should do (as long as CAM isnt above say 276)
Any help appreciated.
Ross.
Ken555
Post by Ken555 »
Here's my current map,
A+ Series 1275cc (modified up to 1380cc)
MED engine, bored to 73.5mm with Omega pistons,
276 Kent cam,
lightened flywheel,
Stage 3 head with 36mm Inlet & 31mm Exhaust Valves.
Weber DCOE 45 carburetor
own.mjlj
(717 Bytes) Downloaded 1148 times
mr_bridger
Hi, Many thanks for that, similar spec to mine... has your car been on a rolling road?
Cheers
Ross.
Salamander
Post by Salamander »
HI ken555
can you make a MAP to my engine? and upload to my post "Testing MJLJ->A-series 1380cc"
-New HIF44 BDL
-Inlet manifold minispares
-1380cc 73.5
-Stage 3 36-30 ported + chamber
-LCB millenium & RC40
-STD rockers (future swiftune 1.5 high lift)
-Swiftune 5 (future Swiftune 10)
-K&N filter
-11:1 CR
-Front radiator
-Lightened flywheel aeg-619
I watching your configuration MAP of your engine, why you start with 24ºand then drops to 8º?
Can you explain a little more the map for your engine.
sorry my english.
Ken555
Post by Ken555 »
Salamander wrote:can you make a MAP to my engine?
I would use this map as a starting point.
Salamander wrote:I watching your configuration MAP of your engine, why you start with 24ºand then drops to 8º?
To prevent the car from stalling (stopping) when it is cold or first started, when the revs drop to 800rpm, it get quite a bit of advance that puts the revs back up a bit.
mr_bridger wrote:has your car been on a rolling road?
No not yet, a few more things to be done first.
Salamander
thanks i test your config in to my engine.
