Hi guys,
trying to get everything I need before my EDIS module arrives from the states,
Does anyone have a Rover 3.9 V8 Ignition map to share please?
RR
Rover 3.9 V8 Ignition map. Please!
the standard default map is good to get started, all the rover builders quote 36 degrees maximum anyway. the only real tweaks i did was to alter the low revs high throttle position area to lose the stumble caused by the carb accellerator pumps... and lift the off throttle area for lower revs.
have a look here... http://www.autosportlabs.org/viewtopic.php?t=1512
You can also try mine. It has inbuilt idle control and rev limiter. Mine is for a 3.5 litre. The 36 degree max is under load. My under load figure goes to 36:
http://www.autosportlabs.org/viewtopic.php?t=1270
This webpage shows that the Rover V8 can go to 38 degrees - this is under load. It mentions that you can put on up to another 15 degrees under light throttle:
http://hometown.aol.com/dvandrews/timing.htm
- tr7v8e.mjlj
- (714 Bytes) Downloaded 1456 times
