I've just bolted the EDIS system into the car without the Megajolt and am observing that the timing mark is jumping between 10 and 20 degrees BTDC. Seems to be about 30% 10 and 70% 20. I have the VR sensor about 2mm from the trigger wheel (crank pulley machined with shallow 'teeth'). Any idea what I need to do to get a consistent 10 degrees? Do I need to move the sensor round a bit or further towards the pulley? or away? Any advice much appreciated.
Steve
EDIS running problems
- Contact:
Yes it would appear so. My pulley was machined as a copy of this wheel (see pic). It would seem that the sensor benefits from steeper sides to the teeth. Hopefully moving the sensor today to get the 10 degree timing. We're getting there!
Steve
Steve
- Machined 'A series' crank pulley
- DSCF1013.jpg (82.89 KiB) Viewed 6972 times
