Hi, I'm having big trouble trying to get the board to connect to the PC.
The software loads up and displays a message window
'As Error has Ocured'
Read buffer length not correct: was 1; expected 128
This only happens when I select COM1 or COM3, & also displays 'Error reading configuration' the bottom of the app window.
Whats gone wrong..
stef.
PC serial problem.
I am also having this same pr
I am also having this same problem. It tells me either error reading configuration, or could not connect to controller. Anyone with ideas as to why it would not connect to the board please help me out. my e-mail is shadowpenguin12345@yahoo.com . Also, anyone with a 4AGE powered AE86 corolla plese tell me what power sources you used.
me to !
i also get this same responce ? have recently just built my board, with correct voltages at all places sugested? have java running with serial support, but just get the response that could not connect to controller ? and help would be much appreciated? i have it on my pc running the latest xp and a laptop running 98 ? same problems on both ? should the serial cable be a straight through cable or a xover ? could this be the problem ?
Had the same problem
I had the same problem and eventually tracked it down to a duff serial cable, the one i am using now is a null modem cable off an old external modem, works a treat
Will a straight serial cable
Will a straight serial cable work proper or do I need a null modem style? I finally got the configurator to work proper then I fought for 2 days wrestling my serial port away from my PALM software and now it wont communicte with my board. I have tried using the Hyperterminal according to the directions with no luck either. My cable OHMS out OK and it is the same cable I use for my Mega Squirt so I am sure it is OK. Any other ideas?
Todd
Todd
So it was working, then stopp
So it was working, then stopped after something changed regarding your Palm software?
it takes a standard serial cable, the same one that would work with the megasquirt.
You want to make sure nothing is controlling that serial port (like the palm software), otherwise other programs won't be able to use it.
Brent
Brent
No, it never has communicated
No, it never has communicated with the board. It took me a while to get the PALM software to let go of my serial port but I did and this was evident thru Hyperterminal. I still get no response from the board thru Hyperterminal or configurator. Is it possible my processor got wiped or was never programmed? Do you know of any way to check this?
Todd
Edit: Please disregard this post due to my ignorance about powering up the board for communications! Thanks
Todd
