Car: Westfield SEiW
Engine Spec: CVH engine with Bored out 1800 American Tall block. Taken to 2 ltr and uses modified Zetec pistons, Stress relieved Con rods, reground crank, Ported head with Piper 285C cam kit (includes different spring rates, and folowers). Approx 10.25:1 Compression ratio.....has around 160 bhp
Fueling: twin weber 40's with 34mm chokes, inlet manifold matched to head ports.
Megajolt ignition
Pics of install:
http://i34.photobucket.com/albums/d102/ ... CF1117.jpg
http://i34.photobucket.com/albums/d102/ ... CF1114.jpg
http://i34.photobucket.com/albums/d102/ ... CF1118.jpg
http://i34.photobucket.com/albums/d102/ ... CF1116.jpg
http://i34.photobucket.com/albums/d102/ ... CF1093.jpg
Westfield with 2ltr CVH and Megajolt............
Thanks guys.....
It was a real struggle finding a position to mount the sensor....but after thinking about it logically it was obvious that the sensor would work perfectly well at 90'........The bracket is no the neatest, and in the future I will probably make another one and weld it and powder coat it, but it does the trick...I put washers on the support arm so I could adjust the distance of the VR.....
Engine was built over winter using a Ferriday 2ltr Block -
I just can't believe how much difference the MJ is making. I also can't wait to get on the rolling road at the end of April to figure out a decent map.....
Hi Jenko
Fairly sure we met at the Hants and Wilts WSCC Dyno Shootout on Saturday at JKM Performance?
I had the prisoner coloured seven with the extra low power
Managed to get some footage onto youtube
http://www.youtube.com/watch?v=iUjE9kOptPc
Going to go back there when I sort the fuelling out and get them to tweak for minimum timing / best power
This time I'll get some more pressure in the tryes - just so I feel better
Regards
Rob
________
silver surfer reviews
Regards
Rob
________
