Ignition map for ford cvh engine...
Jenko
Post by Jenko »
Engine Mfg: Ford CVH
Cylinders: 4
Displacement (cc): 2000
Rev Limit: 6500
TPS or MAP: TPS
Boosted or Normally Aspirated: Na
Modifications: 2 ltr block, zetec pistons, ported head, Piper 285C cam, twin weber 40's.....
Car: Westfield SEiW
Notes: This map was written using trial and error, I'm sure it could be optimised on a rolloing road....but works well, and am sure it work ok with a standard cvh engine also.........Contact me if you have any questions....
mymap_3_after V3.2.1 upgrade.mjlj
(718 Bytes) Downloaded 1136 times
Jenko
Refined map....
Post by Jenko »
Further to the above post...here is another later map that uses less rpm Bins at the top end, so the resolution is slightly better low down....
Seems to work well on modified CVH engines...
mymap_4_11_July.mjlj
(714 Bytes) Downloaded 1005 times
