hello
I use EDIS4 part number 91-AB-12K072-AA but my timing is locked to 10°BTDC,
is it possible that the module not compatible is with Megajolt Lite Jr
timing is locked
I have tried my edis with EDI
I have tried my edis with EDIS SAW Advance Word Simulator,but it remains same the problem my timing is locked on 10°BTDC
my print has been checked, everything look's ok
rgds
bart
rgds
bart
- Contact:
LOS?
This is how the EDIS behaves if it doesn't receive a SAW signal. If you've tried a different SAW source, I would check for a break in the wiring.
