tool for plotting a graph from csv logfile ?
germanz
Post by germanz »
I'm not a excel freak. Does sombody know a tool, that converts easily a csv file to a graph. Or made a smart macro for excel ?
Many thanks
Rainer
themaninthesuitcase
Post by themaninthesuitcase »
Excel really is the most simple tool in my mind. It's quiet easy to do and the excel help is generally quite good.
Oliver Sedlacek
Post by Oliver Sedlacek »
Excel will open a CSV file directly.
david jenkins
Post by david jenkins »
The problem I've found is that all lines are plotted with the same Y axis scale - and some lines are just bumps on the zero line when compared to rpm! :)
Oliver Sedlacek
Excel graphs can have two different Y scales. IIRC what you need to do is select a data set and change it to use the secondary Y axis in the properties dialog.
The wizards in Excel work fairly well for creating a variety of graphs from CSV data. Because of this, I didn't originally include any log viewing tools in the configuration software. However, I can see that it would be very convenient to simply reload and playback the charts- so I'll get that capability on the list for the next software release.
germanz
Post by germanz »
Thanks to all,
my biggest problem is the combined y-scale for all graph.Exactly like david.
Brendt,
is there a rough planning when this promised release will be ?
Cheers
Rainer
