Hey,
I don’t really know what I’m on about but would there be a way to make a sort of immobiliser by cutting a wire and putting a key switch in, or a more high tech way. Maybe even an idea for the next version. Again I know nothing about wiring and only just getting my head around megajolt, so I might be talking total nonsense.
Luke.
Immobiliser.
that duel map idea is really good, could evan maybe use a key switch fitted into the megajolt box instead of a switch might evan look a bit neater than a switch sticking out.
http://www.maplin.co.uk/Search.aspx?men ... &doy=18m12
A key switch will be more secure I suppose - but then YOU need two keys to start your car, and you have to make the MJLJ reasonably accessible (which most people don't) and it might all become a bit of a pain over time.
A relatively well-hidden toggle switch seems a much better idea to me....but YMMV
[quote="luke6040"]that duel map idea is really good, could evan maybe use a key switch fitted into the megajolt box instead of a switch might evan look a bit neater than a switch sticking out.[quote]
That might make it a little obvious what it is for.
How about a reed switch and a magnet to trigger it.
Could be anywhere in the car, but beside the ignition switch with a magnetic key/keyring to trigger it.
http://www.maplin.co.uk/Module.aspx?Mod ... &doy=18m12
