USER OUTPUTS...
mariodantas
USER OUTPUTS...
Post by mariodantas »
Hi friends.......
I've a doubt..... Do the User Outputs act as an earth (Negative) ????
SIERRA 2.0 DOHC 8V or 16V + Ford EDIS4 + Mejajolt = Happyness.........
MartinM
Post by MartinM »
Yes....
If the Output Mode is Normal in the Configurator then when they are:
- not activated, the connection into the MJLJ is open circuit
- activated, the connection into the MJLJ is earthed
If the Output Mode is Invert in the Configurator then when they are:
- not activated, the connection into the MJLJ is earthed
- activated, the connection into the MJLJ is open circuit
Hi Mario,
Yes, the outputs switch ground when they are activated. Also see the following documentation:
Installation guide:
http://www.autosportlabs.net/MJLJ_V3_ve ... hift_Light
Configuring the outputs:
http://www.autosportlabs.net/MJLJ_V3_Op ... le_Outputs
mariodantas
Many thanks to you fellows.....
