charting/tuntime view advice needed
Hi, could some please explain to me how to record the data shown when the engine is running, and what these three ie revs advance load, can help in decision making on what advance should be plotted on the map. people talk about exel which i do not have!!!. many thanks lee
..or even use...
http://sheet.zoho.com/excelviewer.do
...which allows you to see Excel spreadsheets online without any downloads....
Have a look at the Monthly Sales example on...
http://sheet.zoho.com/samples.do
Certainly does do charts!
All it needs is a Zoho registered user to design, save and share a sheet that will chart a MJLJ log file and we're away!
- Contact:
Open Office is a compelling alternative to the MS Office. The charting wizard will let you produce a graph against the CSV data produced by the Configuration Software.
http://www.openoffice.org
You also asked how to generate the log data- see this section of our Operation Gude:
http://www.autosportlabs.net/MJLJ_V3_Op ... ta_logging
- Contact:
