I've just done the TPS calibration for my new carbs - it was a very easy process, but it left me with a puzzle. Where are the settings stored?
I saved the settings to a file when the calibration was complete, but I had expected to have to save them to the MJ unit's memory too, as I thought that it would also want to know the settings!
I had performed the following steps:
1. Plugged in the cable, switched on the laptop and started the config software (which correctly reported that it couldn't get a connection with the MJ unit).
2. Switched on the ignition, and the current table was loaded (correct behaviour).
3. Chose the 'calibrate TPS' option, did the 'closed throttle', 'open throttle' bit and saved the results.
At this point the 'write to MJ' options were disabled.
Should I have been able to write to the MJ, or is it handled a different way?
Or have I simply misunderstood what's going on?
cheers,
David
