RS232 Lead to Laptop
Scottie
Post by Scottie »
I'm a bit of a newbie to this so here goes.
The RS232 lead supplied with my Megajolt has a male/female ends with 9 pins/holes. My laptop though doesn't have an RS232 male or female port, only the 15 pin port for a monitor. Is there another lead i can buy with a 9 pin male end and an alternative end to connect to the laptop? What COMM do i select when i have this lead on the software installed? I have firmware 3.0.
Scott.
MartinM
Post by MartinM »
You need to use a USB slot on your laptop and a suitable USB to serial converter - one of these will suit you, sir
http://www.kenable.co.uk/product_info.p ... cts_id/369
..proven and reliable, unlike some of the slightly cheaper eBay options...
When you will install the adapter it will assign a com port for you - just configure the Configurator to use it and you're good to go...
