79 lotus esprit
79 lotus esprit
components from a ford fiesta
- DSCF2795.JPG (124.33 KiB) Viewed 37784 times
79 lotus esprit
engine pulley is aluminium so a spacer was needed, dimensions given to local machine shop
- DSCF2889.JPG (32.96 KiB) Viewed 37779 times
79 lotus esprit
pulley was drilled and pinned to locate spacer
- DSCF2900.JPG (48.35 KiB) Viewed 37777 times
79 lotus esprit
spacer fits neatly in pulley and locates in dowel pin
- DSCF2902.JPG (40.12 KiB) Viewed 37773 times
79 lotus esprit
pulley, spacer and trigger wheel in place. spare bolt hole and sump bolts will be used for vr sensor bracket
- DSCF2907.JPG (49.73 KiB) Viewed 37772 times
in response to sierra2dr query about dellorto for blow through turbo application, my mate at work has original Dellorto's and blo through plenum off an esprit turbo,its sitting next to his tool box as I asked him to bring it in after I read you were looking. He says its for sale so make an offer
Cheers.
Cheers.
Update
11 years on from the initial installation and I still own the car and the mega jolt is still going strong.
The Tacho however never worked as I never got around to wiring it up
During this time of lockdown I decided to get the smiths RVC tacho up working, along with upgrading the dash bulbs to LEDs.
Using the mega jolt Tach output didn’t work but splicing into the PIP lead got the needle moving
For anyone wanting to know about smiths tachometers, I found this quite helpful
https://www.triumphclub.co.nz/wp-conten ... Smiths.pdf
