Just started trying to map out my 20 hp odd fire twin. I have a small filter chamber to help smooth out manifold vacuum ripples, but I think a larger one may be better. First approach here is to optimize no load advance, looking for maximum vacuum /rpm at a given throttle setting. I will probably need to disable the tractor governor, which tends to distort things. Later, logging will attempt to optimize advance under load.
Perhaps a knob which could give a + or - up to 10 degree shift would be handy, now and for varying weather (120 degree F range) later. Just quickly twist it and see what happens. Then go back & optimize the table. This could easily be done using the AUXILIARY INPUT & ADVANCE CORRECTIONS. I plan to use this to give a quick table shift. The problem with adjusting a point, is the engine then may "slide off" that spot into one that hasn't been updated yet. Moving the surrounding spots involves 9 locations. Just moving the whole table temporarily might be easier. Bruce Roe
Tuning Aid
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
